Removes one or all IGMP groups.
| grpipaddress | Specifies the group IP address. |
| name | Specifies a VLAN name. |
N/A.
This command can be used by network operations to manually remove learned IGMP group entries instantly. Traffic is impacted until the IGMP groups are relearned. Use this command for diagnostic purposes only.
The following command clears all IGMP groups from VLAN accounting:
clear igmp group accounting
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
